power
Old Jan 6, 2007 | 08:31 PM
wheily's Avatar
wheily
Unhappy power
i was wondering if any one can help me my truck has they 5.0 in it with a 168'000 on it and it has no power i have replaced the after cat with a high flow and a new flomaster muff and tail pipe goes out the back kand n filter and a new addjustable fuel pressure regulator set at 35psi the truck can not pull my other truck up a over pass (i tried) and it has 4.09 gears so something got to be rong and my sister got a 95 that has 178.000 and it looks/feels like it has 500hp compared to mineas it leaves me in the dust mine just past smog with no issues and it runs smooth thanks for the help
Old Jan 6, 2007 | 09:29 PM
Conanski's Avatar
Conanski
What year is your truck? What model is it.. reg cab 2wd, ext cab 4x4? What is the compression like? What is the timing set at? What size tires are on it?
Old Jan 7, 2007 | 02:57 AM
eco's Avatar
eco
Too many things to consider and not enough info.
Old Jan 7, 2007 | 07:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 7, 2007 | 06:23 PM
wheily's Avatar
wheily
its a 88 f150 super cab 4x4 with a 5.0 i have 235 75 15 tires the compression is with in spec. dont know timing it was set at the smog shop also the truck was running lean plugs were clean white after 3000 miles so i turned up the fuel pressure but didnt do much but add a little coler to the plugs
Old Jan 7, 2007 | 09:39 PM
Conanski's Avatar
Conanski
White plugs.. yeah that's not good they should have a little color. Changing the fuel pressure is a temporary fix, the computer will adjust for that withing a pretty short period of time. Check for codes, and tell us the running condition of the motor..idles smoothly? Does it ping under load? fuel milage?
The only difference between your 5.0 and your sister's '95 is the cam in the motor. Your's will run at least as well as her's with the right cam. The CompCams 31-255-5 or 35-255-5 are good choices, the only difference is the firing order but both will work fine in your 5.0.
Old Jan 8, 2007 | 08:34 PM
wheily's Avatar
wheily
the truck was ideling smooth ther are no trouble codes coming up no pinging the only thing it does weird is if you stop real quick on a hill or when goofin around and let off the throttle real quick it stalls also is it normal when you first start it in morning it revs real hi then ideles down then it will rev back up when you put it in gear tell its warmed up
Old Jan 8, 2007 | 10:20 PM
Conanski's Avatar
Conanski
Chances are you have a dirty IAC(Idle Air Control) valve. It's right on the side of the throttle body. Unbolt it and clean it out with carb cleaner and a brush. If you remove the actuator the plunger should move freely.
Old Jan 9, 2007 | 08:30 AM
lostin90s's Avatar
lostin90s
Check the timing , it was set for the best emmissions out put. Bet need to advance timing some . Good luck
