302 into 57
Old Jan 6, 2007 | 03:14 PM
dixiefried's Avatar
dixiefried
302 into 57
here goes,i have been offered a 302 to drop into my truck,the truck currently runs a 272 & 4 speed manual,will the 302 mate to the original box,also will the 302 go onto the original mounts for the 272.someone must have done this any info supplied will be most welcome.
also been offered a 460 engine and box but in the land of almost $9.00 a gallon i think this is a little too much.
thanks gary
Old Jan 6, 2007 | 03:18 PM
prostreetrig's Avatar
prostreetrig
302 swap
Hi there, put a late model 302 in my 58, go to Dennis Carpenter, or really any truck site and they have specific mounts for the swap, I think mine were 80 bucks or so, also you will have to get a trannie mount if there is the stock one on there. Hope that helps. James
Old Jan 6, 2007 | 03:21 PM
dixiefried's Avatar
dixiefried
hi james thanks for your input it all helps
thanks gary
Old Jan 8, 2007 | 03:22 PM
dixiefried's Avatar
dixiefried
anymore ideas
Old Jan 8, 2007 | 03:57 PM
packrat56's Avatar
packrat56
Midfifty has mounts, someone on here will know about the trans...
http://www.midfifty.com/
Old Jan 8, 2007 | 04:00 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Yes, engine mounts are readily available from most of the vendors for swapping the engine into your truck. As far as I know the 302 will not bolt up to your tranny. You will need to find a late model tranny to fit which means modifying the tranny x-member and probably the driveshaft.
Years ago I swapped a 390 into a 1960 F-100. U bought the engine mount kit that either bolts or welds into your frame. I made my own tranny mounts as I was installing a 4spd manual and transfer case to make the truck 4 wheel drive.
You'll probably have the normal headackes with exhaust, radiator outlets, etc
With fuel being the high priced maybe you can get lucky and find a late model automatic overdrive to put behind the 302
Good luck
Bobby
Old Jan 8, 2007 | 04:13 PM
dixiefried's Avatar
dixiefried
thanks for your guidance my transmission is a 4speed manual,which i need to identify
thanks
gary
______________________
1957 f100
1927 model t roadster
Old Jan 8, 2007 | 06:25 PM
Snowking's Avatar
Snowking
I understand this is problly what you ant to do but why send another 272 to the scrap heep? Got mine rebuilt for my 1957 worth a million bucks to me to be semi old.
Old Jan 10, 2007 | 01:20 PM
dixiefried's Avatar
dixiefried
the 272 wont go to the scrap heap but into our 27t roadster that is only if i decide to go the 302 route.
