Red Door Light
http://s88.photobucket.com/albums/k1.../door%20light/
POSITIVE wire is fed thru the door and tied into the black wire with blue trace found under the kick panel/door jamb.
GROUND wire is connected to a bolt on the door.
POSITIVE power to passenger door i ran a wire under the carpet from the drives door since i couldn't get wire of same color on pass side to work.
