Pulse wipers ?
Old Jan 6, 2007 | 11:56 AM
KJLYPW's Avatar
KJLYPW
Pulse wipers ?
Any known problems with pulse wipers? Wipers will work in all positions when making changes in position lever, but will normally only pulse once, then nothing.
I've cleaned connections on the pulse circut board connector, but no change. Is it likely the circut board, or the switch on the columb thats at fault?
Old Jan 6, 2007 | 02:39 PM
KJLYPW's Avatar
KJLYPW
Problem solved, Plastic cover on back (front) of multifunction switch removed, lots of WD-40 up into wiper switch seems to have solved the issue for now.
