Back to dealer
Old Jan 6, 2007 | 07:09 AM
satcom40's Avatar
satcom40
Unhappy Back to dealer
Well dec 28 had the dealer replace all four balljoints. Today comming home I switch to 4x4,( road wet and short on ramp) and it sound and felt like the front end was going to fall off, ? could they put is back together wrong, or could this be a new problem. Any input would help. Truck going to dealer on Monday.
Thanks John.
Old Jan 6, 2007 | 08:57 AM
350steve's Avatar
350steve
one of my other trucks is a 95 f350 (gas) plow truck. and on dry roads when turning the whole front end fells like it wants to fall apart, you need both hands on wheel or you will go for a ride in 4 wheel drive even w/plow on 1000+lbs.could be front tires needs to dig in to something. its been like that since day 1. 06 diesel no problem
Old Jan 6, 2007 | 09:22 AM
CanadaGuy's Avatar
CanadaGuy
The way the axles are put into the hub is fairly simple. The only thing that I can think may have happened is that the axles may not have been driven back into the spindle far enough.
