King Pin Size
Old Jan 5, 2007 | 07:33 PM
Brian0445's Avatar
Brian0445
King Pin Size
Are thier different kin pin sizes? Different with weight?
Old Jan 5, 2007 | 09:19 PM
mudmaker's Avatar
mudmaker
Not that I know of. I believe they are all the same dims.
Old Jan 5, 2007 | 09:30 PM
firesoutmatt's Avatar
firesoutmatt
Yes they are the same as the big rigs . You can tow your fiver with a Peterbuilt if you choose.
Old Jan 6, 2007 | 09:51 AM
Brian0445's Avatar
Brian0445
it just seems like their is alot of "slop" or movement when I start or Stop? I have never had it come unhooked but i dont want to be a victim of the flattened bed rails!
Old Jan 6, 2007 | 10:16 AM
firesoutmatt
Is the slop from the pin movement in the jaws or the fifth wheel hitch rocking front to rear ? What hitch do you have ? Does it have the jaws or slide bar ?
Old Jan 8, 2007 | 07:28 AM
Brian0445's Avatar
Brian0445
it is a reese signature series, with a jaw there is no slop in the pins, it is a 7k hitch
Old Jan 8, 2007 | 11:46 AM
firesoutmatt
7k hmmmmmmmm if its the jaw type it should be over 15k . Anyways its prob. rocking back and forth when you stop or go. The only thing to make sure is that the trailer will actually go up when you back under it. Alot of time the trailer will be high enough to lock the pin above the jaws.
