flip axled shocks
Old Jan 5, 2007 | 05:25 PM
custom cabby's Avatar
custom cabby
flip axled shocks
just flipped the axle on my swb.... took helper spring off and used a mopar spring perch that was about 1" thickness so i am expecting atleast a 6" drop. any suggestions on what shock to use and do i have to relocate them? and also what degree should the rear end be sitting at?
Old Jan 5, 2007 | 05:33 PM
BobbyFord's Avatar
BobbyFord
You'll probably have to measure the travel that the shocks will be going through and see if stock shocks will work. I prefer Monroe or KYB's.
Here's a link for pinion angle...
http://jniolon.clubfte.com/driveline...nephasing.html
Old Jan 5, 2007 | 05:37 PM
custom cabby
but i did take away approximately 6" so i think i would have to special order wouldn't i?
Old Jan 5, 2007 | 05:43 PM
BobbyFord's Avatar
BobbyFord
You may have to go behind the counter and measure shocks to find a shorter set with the same ends that fit your truck.
