1978 - 1996 Big Bronco
Mechanical Winch
Old Jan 5, 2007 | 11:15 AM
jaazula's Avatar
jaazula
Mechanical Winch
Dear Sirs:
Do any one of you knows is it is posible to put a 12000 lb winch on a Ford Bronco 1993?. Where can I buy a Power connection required?
In respect of Hydraulic Winch, could it be conected to the hydraulic pump of the steering system?
thanks for your comments and apologize for my English.
Old Jan 5, 2007 | 01:02 PM
Aciancio's Avatar
Aciancio
Yes to both. milemarker has a kit for the hydraulic winch’s it ties into you power steering using bypass valve with safety switches that will close if te winch springs a leak so you don’t loose steering. As far as an electric it depends on the winch each company should have a kit for to match the setup of their winch's
Old Jan 5, 2007 | 02:21 PM
Kemicalburns's Avatar
Kemicalburns
the bummer about the hydro winch is if the vehicle is off so is the winch. vs electric you can usually get yourself unstuck still.
Old Jan 5, 2007 | 04:20 PM
scbronco's Avatar
scbronco
ditto to kemical but if your running your winch straight from your battery you could kill it veryyyyyyyyyyyyy quickly
Old Jan 5, 2007 | 08:47 PM
dwoodler's Avatar
dwoodler
That's why your second battery for winching is an tractor battery! Loads of pull time.
Old Jan 6, 2007 | 01:31 PM
lostin90s's Avatar
lostin90s
Throw and extra battery in and go electric. I had a 8000 lb mounted to class 3 hitch and could move from front to back Had quick conects. Also you put on other truck Had wire to hook from battery to winch. It comes in handy when lets say you truck upside down in the pond. 9True story) Well good luck.
Old Jan 6, 2007 | 01:32 PM
lostin90s's Avatar
lostin90s
Throw in extra battery in and go electric. I had a 8000 lb mounted to class 3 hitch and could move from front to back Had quick power connects. Also you put on other truck Had wire to hook from battery to winch. It comes in handy when lets say you truck upside down in the pond. (True story) Well good luck.
Old Jan 6, 2007 | 02:15 PM
abnormloffrd's Avatar
abnormloffrd
big rv and tractor batteries are not recommended for winches because of the amount of charge time a deep cycle batterie takes to recharge so if your doing repeated pulls the batterie can fail.(according to my interstate dealer who also wheels)
Old Jan 8, 2007 | 08:21 AM
muckypaws's Avatar
muckypaws
Surely you chaps are discussing an Electrical or Hydraulic winches - not a mechanical winch as per the title. A mechanical winch runs directly off the crank pulley or a PTO on the xfer box via a propeller shaft.
however I've never heard of a bronco running with such a winch anyway.
