vibration at 47 mph+
Old Jan 5, 2007 | 08:23 AM
ke12345's Avatar
ke12345
Question vibration at 47 mph+
I seem to be getting a vibration when my f-150 w/ext cab and bed hits speeds of 47 mph and higher. Ford service replaced the u-joints approx. 105k miles on the truck. When I place the vehicle in neutral when its vibrating, it stills vibrates. I sure could use some help.
Old Jan 5, 2007 | 09:39 AM
G'sRed99F150's Avatar
G'sRed99F150
Vibrations can be tricky, but putting the truck in neutral eliminates a bit. Is the vibration coming from the front, or rear.Is your truck 4x4, or 2wd.Do you think your truck threw a wheel weight making the tire unbalanced, you repaced the universal joints, need a bit more info on the area the problem is coming from.
Old Jan 27, 2007 | 02:00 AM
ajm859830's Avatar
ajm859830
As G'sRed99F150 said where is it comming from more so. Have you tried having the wheels balanced/rotated?
Old Apr 4, 2007 | 08:09 PM
amerimutt's Avatar
amerimutt
They might have mixed the position of the drive shaft mount/yoke. ya have to put them back the same way they were taken out, it's called preserving dynamic balance, if not then ya get what you got, but then again you did say the universals were changed awhile back, hmm tire balance weight as suggested earlier
Old Apr 4, 2007 | 08:12 PM
amerimutt's Avatar
amerimutt
Oh s--- this post has got grandkids, I wasn't paying attention
