Offroad & 4x4
the bronco is caged
Old Jan 9, 2007 | 07:28 PM
fishmanndotcom's Avatar
fishmanndotcom
hmm, thats an interesting thought with the chains.
yea i did think about the forklift mounts and i would love to do that but i think mine is a lil too stubby for those mounts unless they have some supersize ones... i'll go measure the girth and come right back and piost up
edit... the girth is 18" and from flat top to flat bottom is 19.25 both measurements on the mark!
-cutts-
Old Jan 9, 2007 | 08:19 PM
RawPower's Avatar
RawPower
If its a normal keg, then you could just drill some 1/2" or so holes in the top & bottom regions of the keg, ie the area that is external where the handles are on the upper part.
Old Jan 9, 2007 | 08:30 PM
fishmanndotcom
see unfortunatley i already went and tig'd the filler neck and fuel line nipples and i put them on the rounded part. what can i say, i got antsy about it, lol
edit... here is a pic i took, its crappy but its all i got!
-cutts-
Old Jan 9, 2007 | 08:32 PM
RawPower's Avatar
RawPower
well tig some more mounts on them! thats probably the best way...
just adapt something like this
Old Jan 9, 2007 | 08:44 PM
fishmanndotcom
well that is sweet, i was kind of looking for an easy way to remove it if need be. i may resort to that. also, i dont have a tig handy, i used the one at skool when i was takin those welding classes, thats another reason i did it then. i am not in those classes anymore so i dont have easy access to the equipment
-cutts-
Old Jan 9, 2007 | 08:55 PM
RawPower's Avatar
RawPower
Oh. Well, then here's how I'd do it.
Mount two opposing pieces of metal on a firm base like this \__/ so that they contact the keg somewhere around 20º to 30º on the keg. Since you said the keg was what, 18 inches? I'd probably space them out about 12.5-14.5" and make the contact areas about 4" long and 3" high. On the upper end of the contact patch, leave it so that it extends out past the area of contact on the keg and drill some 3/4" to 1.5" holes for hooks. Then use two small tie-down straps to keep it in place, hooking from one side of the keg on the mount to the opposing side's mount.
Does that make sense?
Use something like this:
Old Jan 9, 2007 | 09:10 PM
fishmanndotcom
so you think ratchet straps would be ok to use? i am worried that on some trail rides it wont be allowed. for example GrayRock doesnt like ratchet strap batteries!
-cutts-
mustange70's Avatar
mustange70
I'd add gussets at all the joints, what i'd do is bend some tubing up (a 180 bend in some 3/16 stuff) then cut it out and notch it and presto, radius's gussests.
Old Jan 9, 2007 | 09:23 PM
RawPower's Avatar
RawPower
well do they not allow them in fear of the straps getting cut or slashed or in fear of the mechanism breaking?
if its the tearing thats an issue, they offer steel-core straps...
Here is their home page, the good thing is they lock too via key, so that would probably enably them to qualify for the ORV Park regs/rules...
http://www.steelcore.net/
Old Jan 10, 2007 | 02:55 AM
wyldstallyn73's Avatar
wyldstallyn73
I welded a large piece of angle iron (dimentionaly large, not terribly thick) to the ends of keg so that, for lack of a better word, it had "wings" on each side. Bolted the wings to the frame. y
Old Jan 10, 2007 | 03:37 AM
73f350sc's Avatar
73f350sc
Exclamation
Simple...use those water heater safety straps...they're like giant hose clamps you bolt one end on the truck wrap the strap around and tighten it up...give you a firm hold ( after all its designed to hold up a 50-50 gal water heater in an earth quake aint it?) and easy removal if need ever be...problem solved lol. Best part is you can get em at most any big box hard wear store like Home depot or Lowes. And theyre metal so you could probably weld them on??(not sure if theyre aluminum but id bet they are) And paint them if youd like
-Chris
Heres a link w/ a pic from OSH
http://www.osh.com/Cultures/en-US/Ev...aterStraps.htm
Old Jan 10, 2007 | 11:32 AM
RawPower's Avatar
RawPower
I doubt those are alum... it doesn't flex enough. but those might just work.
Old Jan 10, 2007 | 01:13 PM
  #28
captain p4's Avatar
captain p4
those straps look like a good idea to hold my oba tank down, hmm.
I used ratchet straps to hold down my tire and air tank when I went up to RCOP, but it was pretty ghetto looking. It would work temporarily, but I would try to find something more permanent.
Old Jan 10, 2007 | 03:44 PM
  #29
73f350sc's Avatar
73f350sc
Haha yeah....I posted that I thought they were aluminum before I found that link and edited it in...it says they are galvanized steel...sorry.
-Chirs
Old Jan 10, 2007 | 06:26 PM
  #30
fishmanndotcom
now that was a good idea! however unfortunately my lowes/home depot doesnt stock them, in fact the guy in the water heater section said he'd never heard of anything like that, lol.
SO... here is what i came up with! the ratchet straps will work for now but i will be going with metal straps sometime down the line (soon hopefully)
-cutts-
