best tranny
Old Jan 4, 2007 | 07:26 PM
dropshadow's Avatar
dropshadow
best tranny
hey guys i need to know what trans would make my truck a little peppier. i want to keep it auto since my gf mite have to drive it while im workin on her car. plus its easier to just get in and go after bein at the races all night and bein tired. so yea i believe anything that bolts up to the 302 bolts up to the 300 (which is what i have). thanks for any of the help you guys can give me.
Old Jan 6, 2007 | 04:04 PM
Steamir's Avatar
Steamir
I would go with the C6. It's won't give you pep but is heavy duty and very reliable. What year is your truck?
Old Jan 6, 2007 | 08:59 PM
dropshadow's Avatar
dropshadow
my trucks a 91 i was thinking of doing cams and p/p work, a valve job, and a turbo. other then that i dont tihnk theres much more for our motors proformance wise.
Old Jan 6, 2007 | 10:57 PM
85e150's Avatar
85e150
AOD.
You can get wider ratios, and you have the OD. So, you can fool around with the diff ratio and get a combination that uses the relatively narrow power band of the 300 more better than a 3 speed.
Here are some AOD sites, followed by a site with a rpm/mph calculator where you can plug in your ratios and tire sizes. Good luck.
http://www.transmissioncenter.net/AOD.htm
http://ckperformance.com/ford_aod.html
http://www.becontrols.com/products/aodcat.htm
http://www.tciauto.com/Products/Ford/ford_aod.asp
http://www.novak-adapt.com/knowledge/gearing.htm
