Hard To Start..
Old Jan 4, 2007 | 06:16 PM
my69camaro2's Avatar
my69camaro2
Hard To Start..
Left my truck sit for two weeks over the holidays and now it is hard to start... Normally 2-4 tries and a few pumps of the gas... Turns over fine, batteries don't seem to be the problem. When it sat it had 3/4 tank of fuel. I have refueled once after getting back at a 1/4 tank. Once it starts it runs fine and seems to start fine when warm.
It sat in 20-50 degree temps, and is now in the 40's. Been a problem for about 4 days now.
Would it be the fuel filter?
2001 F350 7.3 auto 85,000mi.
Old Jan 4, 2007 | 06:32 PM
ryaneverk2's Avatar
ryaneverk2
When you're cranking and it's not starting, do you see white smoke coming from the exhaust?
I think the glow plug relay might be the problem. You can do a quick test by letting it sit overnight, then the next morning turn the key to Run (don't start it), and use a screw driver to jump the two large terminals on the relay for about 15 seconds. Then get back in the truck and start it... if it starts easily like it should, that would indicate you have a bad glow plug relay.
The gpr is located on the passenger side right next to the fuel filter under the Powerstroke plastic cover, and is the rearmost relay (toward the rear of the truck). The one right in front of it is the intake air heater relay.
Old Jan 4, 2007 | 07:43 PM
my69camaro2
No smoke that I see.
Old Jan 4, 2007 | 11:16 PM
ryaneverk2's Avatar
ryaneverk2
You've gotten it to start, though, after 2-4 tries since the problem started?
Still do the gpr test tomorrow morning or the next chance you get when it's a cold start after sitting for a while.
Old Jan 4, 2007 | 11:18 PM
Kwikkordead's Avatar
Kwikkordead
You may not see much smoke if the glow plugs are cold, just a very fine wisp of smoke. It may also be condensing against the walls of the exhaust pipe before it gets out the tailpipe.
Ryan is pointing you in the right direction, make sure the glow plugs are recieving power.
Old Jan 4, 2007 | 11:25 PM
ryaneverk2's Avatar
ryaneverk2
Damn, Dan .... you're a handsome fella!
Old Jan 4, 2007 | 11:34 PM
Kwikkordead
I was the ugly one of three.
Old Jan 4, 2007 | 11:40 PM
ryaneverk2's Avatar
ryaneverk2
I just saw this one in your gallery:
You must've played football.
by moderators.
Old Jan 5, 2007 | 12:07 AM
Kwikkordead
At 5'8" I would have been crushed.
But nobody could catch me in the 100 yard dash. 11.2 in the 7th grade was my best time.
