Offroad & 4x4
high idle knob
Old Jan 4, 2007 | 03:56 PM
kjg26's Avatar
kjg26
high idle ****
i would like to rig up some sort of high idle **** so i can run the engine a little faster for winching. i know i can make a hand throttle but i saw something at the parts store that was a know for idle control. anyone have any suggestions on how to make something like this?
Old Jan 4, 2007 | 05:32 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
use one of the cable controlled gear changers they have for bikes
Old Jan 4, 2007 | 08:09 PM
evilhorde's Avatar
evilhorde
On some older carburated engines there is an electric solenoid on the carb that was used to help keep an engine from 'dieseling' on after you shut the engine off. When the power is shut off from the solenoid it allows the carb to close up even more than it does at an idle and prevents the engine from running by stopping all of the air from entering. At least I think that was the point of them.
How this helps you: You can use the solenoid to bump up your idle to whatever you want by adjusting location of the solenoid and it will be controlled with a small electric switch instead of some clunky cable and **** system.
Old Jan 4, 2007 | 08:12 PM
75F350's Avatar
75F350
I used an electric solenoid (plunger type) and a switch to provide high idle. Lots of trucks, and cars used this method from the factory to do this for high idle when the a/c was on. They can be modified to provide enough throw to achieve the desired rpm.
Old Jan 4, 2007 | 08:51 PM
kjg26's Avatar
kjg26
KO what did you have in mind for the cable operated one? how'd you attach it to the throttle body?
Old Jan 5, 2007 | 12:15 AM
fishmanndotcom's Avatar
fishmanndotcom
i used an old choke cable, routed it through the firewall and made a bracket that clamped the outer sleeve and then just ran the actual cable through one of the holes in the throttle mechanism. worked very well, i love it!
i got tony to help me out with my high idle on my psd but thats not a viable option for you!
-cutts-
atomicjoe23
28
Jul 12, 2015 06:52 PM
Piolet
Mar 1, 2015 02:05 AM
bigwin56f100
15
Nov 25, 2012 01:18 PM
KHaygood
Jan 9, 2011 04:41 PM
12ozd
15
Jun 20, 2009 11:50 PM
