1950 Brakes
>on the truck was the
>original setup with two lines
>going forward and one going
>to the T-fitting in the
>rear, all directly attached to
>the master cylinder. Now
>I've got a '67 to'72
>Mustang dual master cylinder, and
>NAPA tells me I need
>a proportioning valve. Can
>I just use a T-fitting
>on both the front and
>rear or do I need
>a proportioning valve? If
>I need one ,where do
>you buy one?
With a disc drum combination I now for sure you will need a proportioning valve along with a 2 & 10 psi residual valve. I believe all you will need is to send a brake line from forward most resevoir to the rear and the other to the front. I am not certain about the residual valve because I think they come with the master cyl. I to will be intrested on the comments.
drums front and rear. If it is, it will have the correct
residual valves built into the master cylinder. The residual
valve keeps fluid in the lines and keeps the seal cups in the
wheel cylinders pushed out against the bore of the wheel cylinder. You don't have to use a proportioning valve-it's
just a nice feature the older vehicles didn't have. It delays
the rear brakes applying during a panic stop to keep the rear
wheels from locking up. Some of them also had a plunger that
would shift if you lost pressure to the front or rear and this
would turn a "brake" light on in the car. You could just get
the correct fittings and hook the system up directly to the
master cylinder.
>was for a mustang with
>it is, it will have
>the correct
>in the
> You don't have to
>delays
>rear
>of them also had a
>plunger that
>and this
>in the car. You
>could just get
>master cylinder.
The residual valve can be bought seperatley for 14 dollars at Speedway.
