Could someone tell me if a 300 (4.9) 6 cycliner out of a 79 F - 100 (auto, 2wd) fit in a 1991 F 150 (auto 4wd). If so what other than fuel system? Bolt pattern same for transmission, etc. Engine mount change?
What engine was in the 1991 F-150? The 4.9 engine has the same bellhousing bolt pattern as the 5.0 and 5.8 and so the 4.9 would bolt up to a transmission that was behind one of those engines. However, the 4.9 (0 oz), 5.0 (50 oz post '81 I believe), and the 5.8 (28 oz) are balanced differently so you would want to use the flexplate/flywheel that was on a 4.9 engine. There are some other issues to consider regarding whether the 4.9 will fit. The '79 engine would not be fuel injection while the '91 is. If you wanted to stay carb you would have to remove the high-pressure efi fuel pumps and put a pickup in the tanks or use a regulator that has a return on it and replumb the fuel lines on the engine end. If you wanted to go efi with the engine and the truck was not a 4.9 to begin with, you would have to get all the efi components including ECU, sensors, and wiring.
A guy in one of the other threads said that the frame mounts are different and would have to be changed.
The engine in the 91 is a 4.9 with problems. It still has fuel system etc. All is still in tact. I had a wrecked 79 with a rebuilt Jasper engine & thought they would interchange. Will the head be the same with the EFI or do I need to swap heads since I have all the parts. I thought the basic block may be the only part that would be the same.
I don't think they changed the external engine/head on the 300/4.9 from 1966 to 1996; i.e. the bolt holes are the same in a '66 300 as on a '96 4.9. You would just have to compare motors and switch the different stuff over--manifolds, sensors etc.
One possible difference is the air injection into the heads that the EFI motor has. If you have emissions, you have to worry about it. To solve that, you could just swap heads.
If you are just swappin 4.9 for 4.9, then you won't need to go out and buy anything. While you have the motor out, I would replace as many gaskets as I can, the oil pump, and the pickup screen.
