? on audiophile system/mp3 player
Old Jan 4, 2007 | 10:50 AM
lwabirds's Avatar
lwabirds
Question ? on audiophile system/mp3 player
I have a '06 fx4 screw with the audiophile sound system. It says that it can play mp3's/ipods. How do I connect my ipod or play the ipod through the audiophile system?
Old Jan 4, 2007 | 05:42 PM
screwy's Avatar
screwy
Not sure the 06 had the Aux jack, my 2007 has a little plug up on top of the dash in a corner of the rubber tray thing.
Old Jan 4, 2007 | 07:20 PM
Chris1450's Avatar
Chris1450
my 07 has the jack on top too. I think you just plug it in and select LINE on the radio options.
Old Jan 4, 2007 | 09:46 PM
tbellisario's Avatar
tbellisario
O6' does not have the auxillary mp3 input as does the 07'
I have an 06' and the CD player will only read "mp3 formated CDs" with title, artist etc... on the CD display. You must burn your own CDs to take advantage of this.
I was pissed to figure this out, a harness to hook up your Ipod has been covered in similar forums for about $100
Old Jan 5, 2007 | 09:02 AM
KevinM's Avatar
KevinM
There is an adapter you can purchase that will allow you to use any line level device to be wired directly to the preamp of the factory system. It will also allow you to use the aux button. It plugs in between the head unit and factory harness. The beauty is it keeps you from using the FM tranmitter adapter as a lot are using. FM is limited in frequency response and dynamics, so your IPod will not sound as good as it should.
Go here to get it:
http://www.logjamelectronics.com/piefrd04aux.html
