hot starting problem
Old Jan 4, 2007 | 09:18 AM
1969goat's Avatar
1969goat
Cool hot starting problem
I have a 1996 ford f-150, 300 straight 6 cylinder. Starts fine when cold and runs great when running, but when shut off after driving and motor is warmed up it will not restart. I have to let it cool off for about an hour then it will restart. Any suggustion on where to start looking????
Old Jan 4, 2007 | 09:37 AM
alxsnmr's Avatar
alxsnmr
Obtain you computer's stored error codes first. You also did not mention if it would rotate without starting, or no rotation at all.
Old Jan 4, 2007 | 10:34 AM
1969goat's Avatar
1969goat
It turns over fine, just will not start. I am thinking spark or fuel, but once it cools off then it starts right up.
Old Jan 4, 2007 | 04:24 PM
91250's Avatar
91250
it sounds just like the coil.
Old Jan 4, 2007 | 04:35 PM
alxsnmr's Avatar
alxsnmr
Haynes has a procedure for checking the resistance of the coil but like 91250 says it sounds like a bad or weak coil.
