Ok, Maybe Im slow
Old Jan 3, 2007 | 10:40 PM
Fordtrk26's Avatar
Fordtrk26
Ok, Maybe Im slow
i have 53 ford f100. 3 speed on the colum. Where do I put fluid or lube for the transmission? Sorry I feel dumb but still kinda new at this.
Old Jan 3, 2007 | 11:17 PM
55wagon's Avatar
55wagon
You will need to either get under the truck, or if it has the access panel in the floor unscrew it and pull it out, the transmission will have a fill and drain plug. When you pull the fill plug, the fluid should just trickle out or you should be able to put your pinky in the hole and just feel the fluid when you curl your finger down. If the fluid comes shooting out it is overfilled. I'm not sure which side the drain/fill plus are on, but they should look like a pipe plug. Good luck.
