i have an 01 2wd with a 4.6l motor. i replaced the rotors and calipers a few weeks ago. i am unsure if i have air in the lines or if it is something else. here is what it is doing. braking about 25mph and below 20 mph the brakes work fine. around the 22mph mark i get a funny pedal pressure and i seems like i can feel the rotors and pads rubbing together. as the speed comes down, i get the feel right at 22mph and at 20mph it feels normal. sometimes i have the same feeling around 10mph, but very rare. i feel it around the 22mph just about everytime, unless i am using an extremely lite pedal. any information would be great.
sorry for the delay in responding. i got new rotors and pads off ebay. they are r1concepts. as for bleening the lines, i let almost all the fluid out of the lines and tank and replaced it with syn. fluid. i was thinking it was air in the lines, but i just didn't understand why it only happen at around 22mph. i did clear the hulb and removed almost all the grease. i regreased everything with syn. grease. i was wanting to see if there is anything i need to check out before i call the company i where got the rotors. i was hoping it wasn't a warped rotor. i will check the job again and rebleed the brakes and see if that helps. thanks for taking the time to respond. it has been helpfull.
By "syn fluid", do you mean DOT 5? I don't think it's compatible with DOT 3 fluid unless you completely flush the whole system. Maybe someone else can confirm that.
I wouldnt worry about the fluid, I would think more about air in the lines. You need to have someone open the bleeder valves after you have pumped up the brake pedal, then have them open it up and press down. They should only have to open it a little and air will bubble out, repeat as necessary until no more air bubbles out.
Is your truck 2wd or 4? The axel nut could be a tad bit too loose if its a 2wd.
i dont know why people buy into brake fluid flushes or power steering fluid flushes... theres pretty much no advantage to switching to any type of brake fluid other than what is recommended. Better brake calipers and rotors would be much more worthwhile.
not sure if everyone does a pressure bleed, a gravity bleed isnt good enough.
with new fluid it may be necessary to first bleed at the master cylinder, bleed all the lines there, then move to each brake, starting with the right rear, then left rear, right front, left front(if were being technical)
