1978 - 1996 Big Bronco
94' block in a 93'??
Old Jan 3, 2007 | 08:34 PM
fordfan66's Avatar
fordfan66
My 93' Bronco has a F4 casting on the block. Does this mean the engines been replaced or is it possible it's just part of a running changeover to new 5.8 blocks?
Thanks,
Kurt
Old Jan 4, 2007 | 09:12 AM
Kemicalburns's Avatar
Kemicalburns
that block is a roller ready block. f4te would be the complete casting number. the block will work in any year really. just swap over the parts from the other motor and your done.
Old Jan 4, 2007 | 03:49 PM
fordfan66's Avatar
fordfan66
It is F4TE. I'm not replacing the motor, I just noticed the casting when I removed the starter and it made me wonder if the motor has been replaced prior to me buying the Bronco.
Kurt
Old May 20, 2007 | 03:25 PM
Beanscoot's Avatar
Beanscoot
Hey this is a late reply but I've been searching back posts for info. Your Bronco is probably a late production 93, some of these used the F4TE block casting. So yes, it's a running change to the new 5.8 blocks. Can you find a casting date code on the engine block?
Old May 20, 2007 | 06:27 PM
fordfan66's Avatar
fordfan66
Thanks for the reply. I'll look for a date code the next time I'm crawling around down there, I'm sure it won't be long.
Kurt
Old May 20, 2007 | 07:12 PM
ag30265's Avatar
ag30265
You can also check the build date on the vin tag on the door jam, If it was in the last 4-5 months of 93 then It's probably the original engine.
