Sponsored by: Real Truck
1 ton ride
Old Jan 5, 2007 | 06:18 PM
ubereal2's Avatar
ubereal2
Too soft
Going too soft yes will wear you're tires. On a ton I'd think you're door jam would say to run you're duals about 65 psi? Or does it say higher.
Bob
Old Jan 8, 2007 | 11:17 AM
harald's Avatar
harald
Originally Posted by glsurratt
I've got an F-350 dually with 17 inch tires (These are a new size for the tire industry and there are no inflation charts anywhere on the web). Ford only recommends the higher inflation on the door post. The owner's manual makes no recommendation for loaded or unloaded. I wrote BF Goodrich and they sent me an inflation chart but it has no mention of light or heavy loads and it also doesn't even show a dually application.
When I talked to a Ford rep, they said go with what's on the doorpost. So the truck rides like a one-ton truck (go figure) but when I wear the tires prematurely, I've got all the documentation that says I maintained pressures as recommended.
Ford is going to recommend using their door jamb pressures because they have to play it safe and assume everyone is the average uninformed motorist. It's much better to have too much air in the tire and a rough ride unloaded than to load up a pickup bed with gravel on underinflated tires that will blow out going down the freeway. So you can't go wrong with the door jamb pressures if you don't mind a rough ride. If, however, you want a smoother ride and are willing and able to remember to adjust pressure for new loads, then going with a lower pressure is perfectly acceptable and safe.
Here's a great tire info sheet from Firestone:
http://www.trucktires.com/bridgeston...V_Brochure.pdf
six-seven
Feb 2, 2017 12:47 PM
sam hain
Oct 31, 2016 07:36 AM
parker757
1947 and Older Ford Trucks
Mar 3, 2016 07:18 PM
mwsF250
May 17, 2010 03:14 PM
FordManDJ
Feb 13, 2004 11:36 AM
