points
Old Feb 14, 2001 | 12:44 PM
hodgesmarvin's Avatar
hodgesmarvin
points
how hard is it and what parts do I need if I wanted to change my 1960 292 form points to a electronic ingnition. What do you think of this or is there another way to go.
Old Feb 15, 2001 | 12:39 PM
jaye's Avatar
jaye
points
I'm not really sure if there is a later model 292 with electronic ignition, if so you could get that distributor and use it the hook up is pretty simple the directions are here in the archives. There is also a box you can purchase that will just bolt on its called Pertronix, you can call them at 1800-827-3758 or (909)599-5955 ext. 56 to see if they have your application. or http://www.pertronix.com
Old Feb 15, 2001 | 10:52 PM
fatforty's Avatar
fatforty
points
Hi, pertronix is the way to go changed my mustang over it runs great and the setup was $59.95 John
Old Feb 15, 2001 | 11:10 PM
fatforty's Avatar
fatforty
points
