Steering column swap
only thing you should need to do is remove the column shifter handle. the rest of the shift mechanism shouldn't interfer with anything. and you should be able to remove the cover around the column where the shifter was with the one you have on your stick shift column if you want to give it an original appearance instead of having a hole where the handle was. on older truck the handle was riveted in, not sure about yours, you may have to break out the drill to get it off, but shouldn't be big deal.
