4x4 Conversion
Old Jan 12, 2007 | 02:49 AM
  #31
torch4801's Avatar
torch4801
The 4x4's use a foreward front crossmember, several different steering arrangements, a rear sump 4x4/van oilpan. The f150 4x4 and all 2x frames are the same width. The leaf sprung 4x4's turn tighter but use a narrower frame than the older trucks and highboys that have different bodymounting holes than the 2x. and coil sprung 4x trucks.
What is it about the twin I Beam setup that makes it more difficult - that is, how are the 4x4 front ends different (aside from the obvious differences in axles, steering, etc.)?[/QUOTE]
Old Jan 22, 2007 | 11:11 AM
  #32
samwe's Avatar
samwe
Frame swapping is not much of an option for those of use who have to pass IM based on the VIN number of the frame.
Old Jan 22, 2007 | 11:17 AM
  #33
scottie2hottie's Avatar
scottie2hottie
you can usually have it approved through BMV
Old Jan 22, 2007 | 11:39 AM
  #34
samwe's Avatar
samwe
Lets pretend i have a mid '70's F350 2wd 460 powered truck.
If I find a 4wd frame to use, it will probably not be a 4wd F350 frame because thy are hard to find.
If I use a F250 I can not have a 460, as 460's were not in F250's until the '80's. (At least none that can be proven to the IM referees) In that case I could use a newer 460 if I retained the all IM related parts.
Reworking a crossmember is trivial compared to that headache. I put a D60/and D70 under my Explorer, then worked it hard off road up here, so I have some actually wrench time to back up what I am saying.
Old Jan 25, 2007 | 05:22 AM
  #35
torch4801's Avatar
torch4801
There was a conversion done by 4wheel and offroad where they used a dodge front axle divorced transfercase and springs (because they were plentiful surplus)under a 2x, the lift was enough that the crossmember wasn't an issue.
79fordcummins
Feb 8, 2012 04:53 AM
hoxiii
Aug 12, 2008 11:15 AM
CowboyFromHell
Aug 9, 2008 06:50 PM
hoxiii
Aug 31, 2007 09:17 AM
justin_jkj
Oct 18, 2006 10:55 PM
