pulling
Old Jan 3, 2007 | 07:32 AM
lgower's Avatar
lgower
pulling
98 EB 5.0 awd. had front end aligned a two different places,still pulls to the right,has new tires,even swapped tires around,any suggestions,thanks, LEE
Old Jan 3, 2007 | 10:31 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Do you have the alignment print out you can post on here? Look specifically for the DIFFERENCE in camber and caster between left and right.
If you have more than a .4 degree difference left to right, you're likely going to experience a pull. They may have to install a camber/caster kit to make it adjustable.
Also there's the possibility of a locked up brake, bad control arm bushing (flexing under road force), or a shifted rear axle.
