Steering Question
Old Jan 2, 2007 | 03:54 PM
thamarkman's Avatar
thamarkman
Steering Question
I was wondering if the tie rods and drag link assemblies are interchangeable between a 76' F-150's inverted Y assembly and the 79's separate tie rod/drag link system?
I've got a 76' and would like to put tie rods from a 79'. Thanks.
Old Jan 2, 2007 | 07:19 PM
Mil1ion's Avatar
Mil1ion
Maybe check the part numbers for each truck on this site ?
http://www.rockauto.com/
Old Jan 3, 2007 | 07:51 AM
77460f150's Avatar
77460f150
Yes, they are. I have done this swap twice on both of my 77 F150's. Here is a link to the kit you'll need from Jeffs Bronco Graveyard: http://broncograveyard.com/bronco/i-...kit__stock.htmThis kit contains every thing needed to change to the "T" style linkage except for the pitman arm, the "Y" style pitman arm has the nuckle on it and the "T" style has the nuckle on the drag link. Here are a couple of old threads on this:
https://www.ford-trucks.com/forums/4...n-76-f150.html , and https://www.ford-trucks.com/forums/3...itman-arm.html read post 3 and 6. -Ed
Old Jan 4, 2007 | 02:26 AM
thamarkman's Avatar
thamarkman
Thanks for the information Ed, but just to be clear when I make the swap I will need a new pitman arm from a 78' or 79'?
Old Jan 4, 2007 | 02:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation
All 1973-1979 F150 4X2 .. Pittman Arm with P/S: D2TZ-3590-B
________________
1976/77 F150 4X4 .. Pittman Arm with P/S: D6TZ-3590-D
1978/79 F150 4X4 .. Pittman Arm with P/S: D8TZ-3590-B
Edit: 4X4 info added
Old Jan 4, 2007 | 02:36 AM
thamarkman's Avatar
thamarkman
Its a 76' F-150 4X4
Old Jan 4, 2007 | 02:51 AM
NumberDummy
Post
I posted the part numbers (^^^), but that is the only info I can give you.
Old Jan 4, 2007 | 06:42 AM
77460f150's Avatar
77460f150
Yes, thats correct. All of the parts must be for a 78-79. -Ed
Old Jan 4, 2007 | 09:06 AM
garypettengill's Avatar
garypettengill
I have a '77 F150 4x4 which used the same tie rod and pitman arm setup as the '76. If you change the tie rods to the straight ones from the '78/'79 you must use the '78/'79 pitman arm also. Did the switch on mine, works just fine.
Old Jan 4, 2007 | 03:15 PM
thamarkman's Avatar
thamarkman
Thanks guys I appreciate your help!
