01 Trailer plug issues
Old Jan 2, 2007 | 02:18 AM
idbl_fanatic's Avatar
idbl_fanatic
SO I went to rent a trailer today, and when we went to check the lights, only the left turn/stop/hazard will work, ONLY the left side!! I don't understand this, are there seperate fuses maybe for each function? I have used this before towing and everything worked fine.
Thanks
Old Jan 2, 2007 | 10:40 AM
hookd's Avatar
hookd
check your contacts and then your grounds sounds like somethings not making contact in the plug or you could have a bad ground on that light
Old Jan 2, 2007 | 07:55 PM
hdgapeach's Avatar
hdgapeach
Check the trailer's right side bulb or bulbs? Trailer wired for a Chevy connector (used to make a difference many years ago. Don't know if this still applies now)? Trailer wiring broken on the right side?
Old Jan 2, 2007 | 09:48 PM
idbl_fanatic
We have tested the plug, and there is no juice going to the plugs that should activate the other lights
