Question for the Tranny Guru's......
Old Jan 1, 2007 | 04:12 PM
desertdave35's Avatar
desertdave35
Question Question for the Tranny Guru's......
I was pulling my motor out and the torque convertor ended up coming out with the motor. It ended up spilling about a quart or more of tranny fluid. I put the torque convertor back on the tranny and re-installed the new motor. Didn't think about adding a qt of tranny fluid to the convertor
Will the tranny fill the convertor back up for me if I add the fluid to the tranny?
Its a E4OD in a 1991 Bronco. It goes into gear just fine, felt a little sluggish at first but I just want to make sure, I don't want to burn this convertor up, its new.
Old Jan 1, 2007 | 04:42 PM
lisagoud's Avatar
lisagoud
absoluely...the front pump will make sure the entire unit has fluid including the convertor.(that's the way they work).
Old Jan 1, 2007 | 04:52 PM
RTM's Avatar
RTM
As stated yes it will fill up just fine. Sonce it's a new piece I would change the fluid.
It's a good idea to install a new front tranny seal when it or the motor is out. It's just a good measure to take. If you hadn't already done so. If the motor has a one piece rear main seal I change those out as well.
Old Jan 1, 2007 | 09:28 PM
desertdave35
Thanks guys! Thats what I thought, just wanted to make sure.
