Stuck in 4L
Old Jan 1, 2007 | 08:12 AM
baga's Avatar
baga
Stuck in 4L
Put in 4WL ,tryed all recomended procedures,but it,s won,t come out.
98 Expo
Old Jan 1, 2007 | 05:48 PM
FTE Herman's Avatar
FTE Herman
In neutral, stopped, with foot on brake. Then turn the switch from 4L to 4H and then to AWD/2H. Does this process not work? If so, try backing up a number of yards first.
Old Jan 1, 2007 | 10:17 PM
AGE's Avatar
AGE
It might help to try turning the wheel back and forth while backing up and if that still doesn't work, stop and go forward turning the wheel again to move in a S shaped path. My old Bronco sometimes need this treatment to shift out of 4WD high or Low.
Old Jan 4, 2007 | 02:05 AM
cpettymore7777's Avatar
cpettymore7777
the shifting is done by a electric motor that is mounted on the tcase. they do need to be lubed from time to time. while you are down there you can have someone flip the switch to see if it is moving. you should also hear clicking in the dash while turning the selector switch.
Old Jan 4, 2007 | 11:02 AM
baga's Avatar
baga
Thanks for reply, is there a grease fitting for lube on tcase?
Old Jan 4, 2007 | 01:28 PM
cpettymore7777
no, when you take the motor off you will see the moving parts on the motor and where it makes contact on the tcase. just put grease in there. thats what i did and it works now.
