1992 Explorer Performance Modifications?
Old Jan 1, 2007 | 03:19 AM
rudypoochris's Avatar
rudypoochris
Just wondering how I can take my 145hp 1992 Explorer to somewhere more around 175hp. The car needs a little more spunk. I would rather stay away from the typical exhaust, intake, headers stuff because I am not really sure that they work. Especially on a car that I believe has alot of restriction going on simply in the head design. I have a feeling going with intake, exhaust, headers, etc might kill off my torque. That being said can anyone comment on:
-Chips (the JET modual in particular for CA) - Do they work? Anyone have dyno evidence? How much gain?
-Porting - Anyone done it? How much power can be gotten here on stock heads?
-Can the later SOHC heads fit on the earlier OHV blocks? Is this a very intensive swap if it works?
-Camshaft - Seems there are only a couple of cams out there that are designed from 800-5200ish rpm. That seems like the stock powerband. What kind of improvement will one see, if any?
-Headers, exhaust, and intake... anything that acctually works to make meaningful power and not kill torque? Before and after dyno proof?
To get to my goal of 175ish hp I will probably need larger injectors aswell. I have a feeling the motor might be starved at 15lbs/hr... Can the JET moduals compensate for the change from say 15->19lb or 15->21lb injectors? Can the stock EFI realize the change and compensate? Or will the EFI simply dump more fuel?
Lastly... Does anyone know why the 1991 models were rated at 155hp, 1992 at 145hp (LOW!), and the 93-94 at 160hp? Is this change all in the ECU programming? Rating system? Whats up? Thanks!
Old Jan 1, 2007 | 10:33 AM
quicklook2's Avatar
quicklook2
more air in and more air out is what makes horsepower.
that means exhaust and intake modifications.
sohc heads, no will not work.
chips, after other mods they help.
headers, free flow exhaust will help.
Old Jan 1, 2007 | 11:37 AM
rudypoochris
Intresting... I thought that if I were to upgrade the exhaust and intake system I would have an unbalanced setup and not see much gain at all. Has anyone done just intake and exhaust that would like to coment?
Old Jan 1, 2007 | 11:45 AM
quicklook2's Avatar
quicklook2
do a search on modifications.
no magic answer to performance, usually a combo of things.
