oil prob
Old Dec 31, 2006 | 09:35 PM
fordfanwv's Avatar
fordfanwv
oil prob
i was changing my air filter an hr ago and notices alot of oil in my air box what does that mean i dount think this is a good sign its an 89 f150 -w- 302
Old Dec 31, 2006 | 10:07 PM
petes79f150's Avatar
petes79f150
When was the last time you changed your PCV valve?
Pete
Old Dec 31, 2006 | 10:30 PM
fordfanwv's Avatar
fordfanwv
6 months ago
Old Jan 1, 2007 | 08:50 AM
bronco521's Avatar
bronco521
make sure it rattles yet.thats about the only route oil has to get in there.
Old Jan 1, 2007 | 10:15 AM
HemiEater's Avatar
HemiEater
How can oil get into the air box from the pcv?? This is a good one...
In the box under the element is another little filter that hooks to the valve cover wait wait...
EFI or Crab..........????
and how many miles on it???
Old Jan 1, 2007 | 10:35 AM
bronco521's Avatar
bronco521
isn't there a vacuum in the aircleaner box from the intake?if the pcv is stuck open oil will get sucked into the box.
Old Jan 1, 2007 | 10:50 AM
HemiEater's Avatar
HemiEater
The pcv valve gets it vacuume from the intake..before the air box.
if the thing has a bunch of miles on it the one thing that comes to mind is blow by. if the pcv system can't keep up with the block pressure it will find the weakest place to exit, if the engine has a breather that is feed into the air box from the valve cover it will some times blow oil in the box.
Just under the air filter in the air box there should be a little filter that never gets changed. thats the one that goes to the side of the block or to the valve cover. It's a vent.....and when you get heavy blow by it will blow off the extra pressure from the block into the air box...
Hope I got that right.........
Old Jan 2, 2007 | 07:25 PM
petes79f150
Yessir. That's why I mentioned the PCV. Had the same problem. BTW, just because it rattles, doesn't mean it's good. They're cheap, give it a try.
Pete
Old Jan 3, 2007 | 07:10 PM
mhg's Avatar
mhg
check the pcv hose
old ones will colapse
