Park position
Park position
On an earlier thread topic I had a starting problem, which is pretty much resolved except I need to adjust the gear selector so I can keep the slack out when it's in park. Sometimes I need to push it over in Park so it will start. I have the neutral switch lever aligned up but there seems to be a little slack left in the cable. After taking a quick look there doesn't seem to be much to adjust. Looking under the dash it seems I get just enough play at the selector lever bracket for it to back off slightly and not start. The truck is 12.5 years old , maybe cable replacement time?
Anyone had a problem like this or a quick fix?
Jim
Jim
