hesitation
Old Dec 31, 2006 | 09:19 AM
goochkja's Avatar
goochkja
hesitation
My 2003 expedition hesitates when I go to start is. Once it starts , the vehicle runs perfect. Any remedies??
Old Dec 31, 2006 | 12:16 PM
hdgapeach's Avatar
hdgapeach
Are you describing what might be a "dragging starter"? If so, you may be experiencing the onset of a dying battery. Some local parts stores have the capability to do a load test on your battery to see if it is up to snuff. The cold temperatures of winter is all it takes to knock an older battery in the head sometimes. Worth a check to see if that's all it is. Check for corrosion around the battery posts too. That'll also contribute to restricted conductivity. Re-post with the results or more signs/symptoms if it turns out not to be the battery.
Old Dec 31, 2006 | 07:37 PM
goochkja's Avatar
goochkja
hesitation whe starting
it is more of having a hard time turning over. Only happens whe the vehicle has not been used for a couple of hours. Someone once suggested cleaning out the IAC valve. But the problem in not in the idleing but in starting. If that makes any sense??
Old Dec 31, 2006 | 09:41 PM
sbclemens's Avatar
sbclemens
Does the starter spin normal?
Old Jan 1, 2007 | 09:27 AM
hdgapeach's Avatar
hdgapeach
Sounds like my Expedition when the battery is on its way out. Once you get it started, it runs fine. But, it'll sure spin over slow trying to start.
Old Jan 1, 2007 | 09:53 AM
sbclemens's Avatar
sbclemens
Due to the desert heat, I replace my battery every two to three years. I get one hard start warning and then I know the battery is on its way out.
