turbo timer
Old Dec 30, 2006 | 09:48 PM
yamaguy's Avatar
yamaguy
turbo timer
I was looking on ebay at turbo timers and there were a few on there that looked like they were made of radio shack components, and only had 3 or 4 wires to hook up. Has anybody ever made one up? Maybe there is a diy that I havent seen. I'm sure Kwikkordead has probably done it.(he seems the type)
Old Dec 30, 2006 | 10:01 PM
powrstrkn''s Avatar
powrstrkn'
I don't know of anyone on any of the forums that built there own.
I don't have one I just watch until my egt's hit 300 and shut her down, it only takes a minute or two for this to occur. If you really want one check out some of the site sponsors. They seem to have pretty fair pricing.
Old Dec 30, 2006 | 10:38 PM
PSNut's Avatar
PSNut
Some remote starters have the timed shutdown feature.
Old Dec 30, 2006 | 11:19 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
This is what I use and it works great, plus its plug-n-play:
http://www.dieselsite.com/index.asp?...PROD&ProdID=29
Or you can go with a crimestopper alarm
Old Dec 30, 2006 | 11:22 PM
aklim's Avatar
aklim
Why do we really need it? I mean, is it really an issue for say normal driving?
Old Dec 30, 2006 | 11:31 PM
RAMPAGE_F350
Probably not, but personal preference is what led me to get mine. Some say 400-300 is the safe-zone. Some only use them for towing reasons. Wheather its necessary of not, I let mine cool down to 300 before every shut-down. Probably, because of my rebuilt turbo.
Old Dec 31, 2006 | 12:42 PM
CSIPSD's Avatar
CSIPSD
you do not need one... its a old OLD throw back thing when oils were not as tough as they are now. Shut it down when it gets to 350-400 and you will be fine. Almost 750,000 miles on PSD's and never a turbo failed from hot shut down.
Old Dec 31, 2006 | 12:43 PM
aklim's Avatar
aklim
I check my gauges but it seems like when I shut it down it is at 300-400. I suppose if I had be dragging it with EGTs at 1200 or so, I would let it cool down further but in this case, by the time I settle it down and park it it is already at that range.
Old Dec 31, 2006 | 01:00 PM
GREGROB's Avatar
GREGROB
Adding to what Joe said:
This is outdated thinking that goes back a long time ago for two reason.
First, oils were much more prone to "coking" back then than they are now. Upon hot shutdown, the oil would sit in the center cartridge of the turbo and cook, leaving a solid, ashy residue which was not good for the bearings.
Second, the bearings back then were made of babbit, a softer more malleable metal that was much more prone to distortion, especially with the ashy deposits from the coked oil circulating through the center section.
Enter the days of more refined oil ingredients, and better metal choices for sleeve bearings, and the need for cooldown is almost non existant.
I'll admit though, I do wait for mine to dip down to 300-350 upon shutoff, more out of habit than anything else from when I did not know this.
I would be most conscious of it after a long hard pull, when towing, etc.
Definitely wouldn't climb the hill to the rest area with foot to the floor, grossing 25K+, whip in at 800º, shut her down and run to the potty!
Old Dec 31, 2006 | 01:04 PM
aklim's Avatar
aklim
Originally Posted by GREGROB
I would be most conscious of it after a long hard pull, when towing, etc. Definitely wouldn't climb the hill to the rest area with foot to the floor, grossing 25K+, whip in at 800º, shut her down and run to the potty!
That is what I mean tho. By the time you get to your destination, you have to slow down. Then you have to go real slow till you get it parked, hit the E-brake, take the seat belt off, etc, etc. Look down and my gauge is always under 400
Old Dec 31, 2006 | 01:13 PM
GREGROB's Avatar
GREGROB
I must have a problem with my truck then.
Normally I slide in my drive broadside, go tokyo drift around my uncles house, blow liberal smoke on the neighbor's horses, slolum btwn my ATV trailer, outside water spicket, VW bug, and Taurus SHO, land in my parking spot, and jump out the window, slide across the hood Duke style and unlock my front door.
Wonder why mines always like 550-600
Old Dec 31, 2006 | 01:18 PM
seventyseven250's Avatar
seventyseven250
did you ever know that you're my hero . . . .
Old Jan 1, 2007 | 04:47 AM
GREGROB's Avatar
GREGROB
LOL, I just noticed this.
Thanks! I'm no hero tho.
1Fastboy
Dec 21, 2014 06:31 AM
1Fastboy
Apr 10, 2013 09:01 PM
Regulator1988
May 29, 2012 07:47 PM
clueless
Oct 29, 2006 10:06 AM
