Coil Voltage Question
Old Dec 30, 2006 | 02:18 PM
VirginiaWiFinder's Avatar
VirginiaWiFinder
81 F150, 351m 4x4 Auto.
Ok,
I know that a stock coil should run at 6 volts. I upgraded to an Accel super coil that operates at 12V constant. So I swapped out the resistor wire for a standard wire to supply 12V constant to the coil.
When I measure the voltage from the ground of the truck (not the coil side) and the (+) side of the coil I read 12V.
When i measure the voltage between the (-) and (+) sides of the coil I get about 9-10V.
Any ideas why this would happen?
Old Dec 30, 2006 | 02:37 PM
Mil1ion's Avatar
Mil1ion
Ford Coil voltage is actually 8.2 volts minimum
What is the voltage from - terminal of coil to ground ?
- is the tach reading which means ...grounded then open..then grounded.
What is the continuity test result between those two terminals ?
http://www.fluke.com/application_not...AGID=1&SID=103
That is more important
Old Dec 30, 2006 | 09:27 PM
VirginiaWiFinder
Holy cow...my accel super coil exploded. Literally....it blew up. I guess the coil was damaged when it was shipped to me and I did not know it. That is what I get for buying one off eBay.
Anyway, I went to autozone and got another coil. But now there is no negative polarity on the coil. (+) side of coil to chassis ground = 12V. (+) side of coil to (-) side of coil = 0V.
Now what. When the old coil blew did it take out the ignition module?
Old Dec 31, 2006 | 12:42 AM
Mil1ion's Avatar
Mil1ion
That was my point.
AFAIK, There shouldn't be any voltage from the - neg terminal of the coil to ground in certain positions of the distributor rotor.
That is the TACH signal wire.
