(did a search already) Alt problems
Old Dec 30, 2006 | 12:12 PM
gixxerbilly's Avatar
gixxerbilly
I have a 90 F150.Battery went out on me last week.Bought a new one put it in
yesterday.Started right up,but the gauge on the dash was peged out at 18 volts an the
battery light is on.When the truck idles its normal but when it gets above 1000 rpms its
back up to 18 volts.What gives???"??I took the Altinator to the parts house they put it on
there test bench an it was working fine .........ARGHHHHHH!!!!!!!!!!
What now??????
I did a search cant find anything that matches my problem..
Please help.
thanks
Billy
Old Dec 30, 2006 | 02:48 PM
95X15's Avatar
95X15
You may well have a wiring problem - you need to get a voltmeter and check the voltage while idling and a higher RPMs. Should have 13.5 to 14.5 volts at idle and above if charging properly - the meter on the dash may or may not be reading right.
The only tine I had a battery light on 88 model the regulator in alternator was gone, putting out too much valtage which will cause battery to die.
If you don't have ameter go to a goof electric shop in your area.
Good luck.
Old Dec 30, 2006 | 03:10 PM
Conanski's Avatar
Conanski
The benchtop alternator testers are junk!! $$ says the internal regulator on your alt is fried, swapping in a new or rebuilt unit should fix the problem.
Old Dec 30, 2006 | 06:43 PM
dv_shane's Avatar
dv_shane
mine went out and i put a 125 amp chevy delco alt on and it works good just had to fab 2 brackets uses same stock serpintine belt. i dont like ford alts and i had a chevy just sitting there.
Old Dec 30, 2006 | 07:04 PM
Conanski's Avatar
Conanski
Maybe you should be driving a Chev then.....
Old Dec 30, 2006 | 07:59 PM
gixxerbilly
gotter going........thanks guys
