Transmission / Differential ID
Old Dec 30, 2006 | 09:12 AM
Ogriv's Avatar
Ogriv
Question Transmission / Differential ID
I am a bit confused and perhaps you all can set me straight. I am trying to identify my transmission and my differential. Now I must say, that I know where these items are physically, but I am confused on how to determine which type I have. I keep reading about folks having a "Dana" or a "Ford" diff, but how do I determine which one I have? Same with the manual transmission, is it a New Process with or without extension, is it a Warner......Argh
The tag that is hanging from the differential has some numbers stamped into it. They apppear to read as follows:
1st line: S 608 D -This line is hard to read, so this may be incorrect
2nd Line: 55 8 8 7B23
I cant find any tags on the transmission.
1987 F150 300 I6 2WD
I have 4 forward speeds (including Granny Gear) and 1 reverse gear. The shifter is located on the floor.
Any help would be appreciated.
Old Dec 30, 2006 | 11:48 AM
andym's Avatar
andym
The tranny is most likely a BW T-18. The NP 435's were rare by 87 - I think 86 may even have been the last year you could get one. The rear axle is a Ford 8.8" with a 3.55:1 ratio.
Old Dec 30, 2006 | 02:23 PM
Ogriv's Avatar
Ogriv
Thanks for the reply! <p>
I replaced the transmission fluid today with 3.5 quarts of 80W-90 gear lube. I was going to replace the differential fluid as well, but the Haynes book says to use "HYPOID GEAR LUBE". Can somebody clarify what that is?
Thanks again.
Old Dec 30, 2006 | 08:45 PM
Ogriv's Avatar
Ogriv
Ok, I after doing some research, I realize that Hypoid is the type of gears in the differential. So does this mean that the standard 80W-90 that I used in the transmission won't work?
Thanks.
Old Dec 31, 2006 | 12:36 AM
hadman50's Avatar
hadman50
I'm pretty sure that the oil you added is just fine. The rear end takes more stress on the oil than the transmission does. And almost all gear oils are rated as hypoid type
Old Dec 31, 2006 | 08:02 AM
Ogriv's Avatar
Ogriv
Thanks for the help.
Old Dec 31, 2006 | 12:21 PM
Ogriv's Avatar
Ogriv
I got the differential fluid changed today! All went well. Thanks again for the assistance.
Old Dec 31, 2006 | 12:30 PM
T.R.Bauer's Avatar
T.R.Bauer
80-90 gear oil is for hypoid gear; no worries.
