Hubcaps
Old Apr 2, 2001 | 04:18 AM
55forder's Avatar
55forder
Hubcaps
Old Apr 16, 2001 | 03:15 PM
58Model's Avatar
58Model
Hubcaps
Are the hubcaps from a 3/4 ton the same as a 1/2 ton in a 1959 model? If this is an incredibly ignorant question, I apologise in advance! Thanks!
Old Apr 16, 2001 | 05:47 PM
cobraguy's Avatar
cobraguy
Hubcaps
I'm pretty sure there is a difference. The rims are different so it stands to reason that the hubcaps would be also. You had also asked some time back what a 3spd toploader was it is the same basic design as the famous 4spd toploader with 1 less gear. You can identify it by it's removable cover on the top and shift levers that go through the side. I had a 351C putting around 400HP through one and never broke it. They're found in many of the pickups I've seen 50s-80s.
Old Apr 17, 2001 | 03:32 AM
58Model's Avatar
58Model
Hubcaps
Thanks for the information!
