Sponsored by: Real Truck
Help Please
Old Dec 29, 2006 | 07:22 PM
900rr's Avatar
900rr
Help Please
I have a 2000 cc v10 super duty with the auto locking hubs i have read many posts about no vacum my problem is that the dealer replaced the right hub because it would not work in auto i just pickrd the truck up and still not working the best part is that the dealer stated that for it to work it must be sliping or the truck must go into a slide .so i went home got in some mud and guess what? suprise no 4x4 the back wheels just spin. incase you would like to know it does work in lock any help for me to tell the dealer would be great by the way it is a for dealer and not some back yard mechanicplease post back as soon as possible my warranty is going to run out very very soon
Old Dec 29, 2006 | 07:26 PM
PHWLEE's Avatar
PHWLEE
You've tried setting the hubs manually to locked? If it goes into 4 wheel that way, then it should be vacuum or solenoid. I would check the lines getting to the solenoid and the unit itself.
Old Dec 29, 2006 | 07:29 PM
900rr's Avatar
900rr
i have checked the lines they are getting bad but i even tried to unhook the line for the ac vent that taps into the selonoid and it had vacum but still never went into 4x4 any heip please
Old Dec 29, 2006 | 08:22 PM
900rr's Avatar
900rr
what info i am looking to get is that these hubs are not or are they centifical in that you must be slipping for them to engage then they will release when not slipping please verify this so i can tell the dealer that they are full of you know what
