Reverse lights
Old Dec 29, 2006 | 02:47 PM
Olddog66's Avatar
Olddog66
Reverse lights
I want to tap my reverse light signal and send it to a relay that will control power to a pair of lamps I’m putting on my bumper. It looks to me that the best thing to do is tap the reverses lamps at the back of the truck and put the relay under the back of the truck bumper. If I see things correctly the DTR is located on the transmission and not under the dash so I can’t wire this relay in the truck. Any suggestions? I figure 14 gauge for the run from the battery to the dash with a 15 amp fuse and I’m going to place a three way toggle so I can run lights on always, lights off, and lights on reverse….then a run to the back of the truck for the lamps. I have two 55 watt lamps and I figure 10 amps max for the current and 14 gauge for the run should handle it. If I can find a reverse signal wire under the dash it will prevent me from running two wires to the back of the truck, one for always on and one for the relay. Any input would be appreciated I’m just running ideas trying to think of something I skipped.
Old Dec 29, 2006 | 02:51 PM
powrstrkn''s Avatar
powrstrkn'
I have two 55w lamps like you want. I didn't feel the need for a switch so I tapped the reverse light power wire and left it at that
It will not blow the fuse
Old Dec 29, 2006 | 02:54 PM
Olddog66's Avatar
Olddog66
Fuse?
Do you know what the amps are on the fuse that feeds the reverse lamps.
Old Dec 29, 2006 | 03:02 PM
powrstrkn''s Avatar
powrstrkn'
! think its 15amp? I don't know for sure. If you want try a search in the superduty forum. I'm sure theres some recent threads about this.
