Heater problems
Old Dec 29, 2006 | 11:34 AM
2000_exc's Avatar
2000_exc
Heater problems
I have a 2000 excursion whith heater problems. Sometimes it blows hot air and sometime it blows cold air. The only thing I could think of is to change the thermastat. I did not think this was the problem but had to start some where. Does anyone have a suggestion on what to check next? thanks
Old Dec 29, 2006 | 10:23 PM
Jetfixr's Avatar
Jetfixr
How long have you had your Ex? Some have added a water shutoff valve that closes when you have the A/C set to max. Others have done other mods to close it manually or at different settings. The Ex does have a valve as original equipment you should check there for heat on both sides of valve when the heat is not working. It's on the rh side of my 6.8L above the valve cover. I'm not sure about the other engines.
Jerry
Old Dec 30, 2006 | 09:22 PM
2000_exc's Avatar
2000_exc
Thanks for the post I will check that out. We bought it new and have not modified anything for the heat and A/C.
ballow97
Feb 17, 2014 01:31 PM
rickbrad
15
Aug 5, 2011 12:16 PM
foman13
1997 - 2003 F150
Feb 1, 2011 12:38 PM
cajun1965
1997 - 2003 F150
Oct 9, 2010 08:24 AM
tobyw
Nov 21, 2001 01:36 AM
