Battery Gauge?
Old Dec 29, 2006 | 08:23 AM
spadasak's Avatar
spadasak
Smile Battery Gauge?
I have a new '06 F350 Lariat and there doesn't appear to be a battery readout. Is this normal? I see the turbo boost and transmission temp. was added, which is great. Maybe the voltage isn't as important.
Old Dec 29, 2006 | 08:25 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Yep, it's normal. My '06 Lariat does not have one either! I guess having two batteries, it's not such a big issue, but I might add one when I get my pillar gauges!
Old Dec 29, 2006 | 08:33 AM
FloridaF250's Avatar
FloridaF250
Yep thats normal. I thought the same thing when I got my 06 F250. Temp is the biggest thing along with oil pressure.
Old Dec 29, 2006 | 08:42 AM
Lonewolftx's Avatar
Lonewolftx
Wink Try here . . .
Yeah, Ford decided to leave it off but with all the power needed to run these 6.0's I think they screwed up. Put one here as my A Piller pods were full . . .
Old Dec 29, 2006 | 08:46 AM
FloridaF250
that looks sharp there, whats the switch for. Enquiring minds - Air horn by chance? If so when I add a horn I would like to run the switch to one of my Outfitter switches can I?
Old Dec 29, 2006 | 08:50 AM
Wingedpig's Avatar
Wingedpig
Very nice looking install. I'm impressed. I'd also like to know what the switch is for, as well as the indicator light.
You've done it now, posting a pic of your very sharp looking work.
Old Dec 29, 2006 | 08:52 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
That looks sharp! That is the same kind of gauge I am going to get for my pillar gauges. Is it hard to see there?
Old Dec 29, 2006 | 08:55 AM
FloridaF250
the indicator light looks like it's for maybe a anti-theft system. IMO. On my 2001 F150 I put a viper in it and thats the same kind of light.
Old Dec 29, 2006 | 09:37 AM
Lonewolftx's Avatar
Lonewolftx
Wink Here are the answers for the enquiring minds . . .
OK, OK, . . .
  • Indicator light is for security system Viper from my '03 F150 truck
  • Red rocker switch is to change between my air horns or my OEM horns. You can't use an upfitter switch to change between the two horn setup as they are live wires. The OEM horn is activated by a ground wire at the steering wheel button. The witch is a DPDT as I couldn't find a SPDT one @ radio shack but it works fine. It allows the air horns to ground or the OEM's
  • It isn't the best location to see the guage but it's not like I need to view it continuosly, just when I want to check what is going on with the charging system
  • My A Piller is setup w/ autometer Tranny temp, Boost, & EGT guages.
Old Dec 29, 2006 | 10:42 AM
tex25025's Avatar
tex25025
Most of your digital gauges will have a volt meter on it and while that at the time wasn't why i had gotten a digital one, it comes in handy when you have four gauges(3 of which, egt is fixed, you can change to whatever other gauges that they offer that you want) and it all takes up the space of a single gauge pod on the A-Pillar. Plus I think it's more accurate, although not as cool looking, as an analog gauge, but ford did make a mistake by not putting one in(of course, even if they did put one in, I would be leary of it being like the tranny temp gauge, not all that accurate).
Old Dec 29, 2006 | 10:43 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
thanks for the info! Yes, we are waaaayyy too nosy!
Old Dec 29, 2006 | 01:19 PM
jimmy-six's Avatar
jimmy-six
I have a Bully Dog monitor. One of the 4 displays I choose was the Volts. 2 EGT's and Boost finish it out. So far it stays right at 13.2 for the last 2 years...Good Luck
Old Dec 29, 2006 | 11:10 PM
Lonewolftx's Avatar
Lonewolftx
Arrow
I was wondering how you can state that your digital is more accurate? The Boost and EGT are mechanical and the tranny temp is an probe w/ electrical sender. Volt is electrical hooked into the wiring system so how is your digital a more accurate setup?
I can see where it might read a decimal point but that doesn't make it that more accurate IMO. . . .
Old Dec 30, 2006 | 07:11 AM
tex25025's Avatar
tex25025
It's accurate in how your reading it. The display is more accurate, so in consequence, you know exactly where you are at. My boost shows 13 on the digital, where is the factory boost or even the other mechanical boost, your off in no man's land between tick marks. Same thing with egt's, the display will show your past the 6, but your not at the half way point between 6 and 7, so your somewhere between 600 and 650, but on my digital display it will tell you, you are at 635, that is what I mean by more accurate. The probe itself might be reading 635, but you will have to make a judgment call on were you are at based on where the needle is on your mechanical gauge. I'm not questioning the accuracy of the probe itself, it's the accuracy of the display and how accurate we intreprete what we are reading on the display.
For instance, your voltmeter, it shows that 13 is the tick mark between the 12 and the 14, based on the size of the needle, there is no way you can accurately judge 13.1 or 13.2, which during operation is what mine is showing, and when I start the truck up it's showing 12.8, there is no way that we can accurate say that is what we have on a mechanical gauge. That is what I mean by accurace, not the probe itself, but the displaying of the probe's information to use. It is almost irrevalent how accurate the probe is, if the displaying method isn't AS accurate as the probe that it uses to gather that information.
Old Dec 30, 2006 | 08:22 AM
Lonewolftx's Avatar
Lonewolftx
Ok, then . . .
So all in all how helpful, really, is knowing 635 vs. an estimate of something between 600 and 650?
If you are charging at 13.2 I would say you are low as it should be at 14 and I would guess a regular guage would show you on the high side towards 14 (as normal) vs the low side towards 13 (low). Have your Alt checked.
As these guages go, unless you are really pushing it all the time, the difference between the two is overkill but nice to know. Glad you are happy knowing to the exact decimal, your engine perfoirmance.
I am happy happy know the range it is working in and where it might be headed if things go bad.
