wiring woes...need help!!!!!!!!!!!!!!!!
Old Dec 28, 2006 | 08:21 PM
crack's Avatar
crack
ok, I wired up my lightforce lights today, and put the switch right beside my DP switch...the lights are wired into the hi beam...with the hi beams off and flicking the switch everything is fine...with the highbeams on..turn the light on, they work, switch it off and it cancels out my chip for a second....when I was tesing the lights it shut my truck of once....and sometimesthe check engine and wait to start lights come on.......how could the switch be effecting this?
Old Dec 28, 2006 | 08:27 PM
mech2161's Avatar
mech2161
The chip switch works with a very low voltage. Static electricity can effect a computer.
RAMPAGE_F350's Avatar
RAMPAGE_F350
Jody and Dianne are shipping out a shielded replacement nine pin cable to replace the ones that came with our F5 tuner. Apparently, the non-shielded cable is prone to interfere with other electronics.
Old Dec 28, 2006 | 09:11 PM
crack's Avatar
crack
so basically I have to wait for the new cable.... or move it away from the switch?
Old Dec 28, 2006 | 09:18 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I would say yes to both. Definately a bummer when the truck dies.
Old Dec 28, 2006 | 09:19 PM
RAMPAGE_F350
Most likely.
Old Dec 31, 2006 | 09:24 PM
DaveWilliams's Avatar
DaveWilliams
Mine does wierd things too
My truck randomly locks the doors, unlocks the doors and flashes the parking lights. Jody said the shielded cable will fix it. I moved the cable and it seems to help out tremendously. Today it only locked and unloced the doors once. I am sure the new cable will fix our stange happenings. Jody rocks and the lope idle sure makes some power..........
saxmancon
May 2, 2022 04:48 AM
I_Am_Ozymandias
Feb 26, 2015 08:50 AM
sledjunk
Jul 18, 2013 10:31 PM
ZEALOUS_DRAGON
Jan 19, 2011 09:23 AM
firehawk198
6.4L Power Stroke Diesel
17
Apr 25, 2007 04:24 PM
