gear ratio swap
Old Dec 28, 2006 | 07:53 PM
jackeduptruck99's Avatar
jackeduptruck99
gear ratio swap
i have a 97' ford f-150, with a 5.4, automatic. the truck has a 7" lift and runs 35's. i have been wanting to change the gears for a while, however, if i change the rear to 5.13, will i need to make any adjustments for the front end? i always thought the front and rear gearing had to match. i know with my ifs there is no front dif, but surely there is something that regulates the gearing right? any one know anything or every done something like this?
Old Dec 29, 2006 | 07:26 PM
andym's Avatar
andym
There's no front diff? Your truck is 2wd? Gears go inside the differential, so if your truck is not a 4x4, then there are no gears in the front to replace.
Old Jan 1, 2007 | 06:15 AM
Quigoline's Avatar
Quigoline
If it is a 4x4 you have a front diff...It sounds like you are thinking of a solid front axle, one that looks like your rear end but allows the front wheels to turn.
I think the F-150 IFS has the diff. on the left arm????
513 gears...!!!...I don't know if your rears can accept them...some housings are made for a certain ratio down and then others for ratio's up...you need to do alot of homework first...good luck
Old Jan 2, 2007 | 06:47 PM
jackeduptruck99
thanks for the input guys, i never thought about the truck not taking that size gears. i'm moving up to 37's and when i looked at the chart at four wheel parts it recommended 5:13's. i thought it was a bit over kill anyways. i guess i'll check what size can be put in there. i pull my travel trailer quite a bit and was looking for a little more power. thanks again!!
Old Jan 2, 2007 | 07:13 PM
andym's Avatar
andym
What axles are in the truck? You still haven't said if it's 4wd or not. Check out randysringandpinion.com or yukongear.com to see what's available.
Old Jan 3, 2007 | 12:57 PM
jackeduptruck99
it's a four wheel drive. i don't know for sure what axle is in it, but it has the 5.4 so it should have the bigger one. we swapped my friend's rear end out on his and i remember his was smaller because he had the 4.6.
