hello from new 94 explorer owner...
Old Dec 28, 2006 | 06:36 PM
quicklook2's Avatar
quicklook2
i am a regular at the 87-96 f150 forum and i just picked up a 94 explorer xlt 4x4 auto.
i got it real cheap from a friend who could not get it to idle. they are not mechanically inclined like i am.
heard an exhaust leak and it turns out to be egr pipe broken at bottom where it meets manifold. probably 80% of the trucks problem.
no owners manual, any one have a pdf version?
has manual locking hubs, how do these work? do i leave them on lock to use with the buttons on the dash?
thanks in advance for any help.
Old Dec 28, 2006 | 06:47 PM
aquanaut20's Avatar
aquanaut20
leave the hubs unlocked unnless you are going into terrain that would require 4x4, then you may lock them in and run the truck in 2x4 until you press the 4x4 button, this wll lock the T/C and give you 4 hi, stop, shifter in N and foot on brake, button to 4 low and viola you are in 4x creep mode.
Old Dec 28, 2006 | 07:04 PM
quicklook2's Avatar
quicklook2
thanks, that is what i thought.
if the truck was run with them locked but the switch turned off would it hurt them?
is it a good thing to have the manual hubs?
Old Dec 28, 2006 | 07:25 PM
aquanaut20's Avatar
aquanaut20
when the hubs are locked the drive train will spin up to the t/C clutch, will not engage 4x4 until you press the button.
Old Dec 30, 2006 | 11:39 AM
sjwoody's Avatar
sjwoody
I have a 92 Explorer with auto hubs and a 94 Ranger with manual hubs. They have an identical drive train except the Rangers drive line is longer.(I haven't checked yet if the axle ratio is the same!) Anyway, I suspect the Ranger came with auto hubs which were replaced with the manual hubs before I bought it. I've heard the auto hubs will fail after awhile, and the manuals are way more reliable. I haven't had any problems with either, but I make sure the auto hubs are greased sparingly. Too much grease was their main problem. If I need 4WD, it's nice to just push the button with the auto hubs, and everything comes on. With the manual hubs, I have to set them before I start out. This will cause the front axle and drive line to rotate, but the transfer case isn't engaged until I push the button inside. Follow the owners manual guidelines for engaging (and disengaging) the 4WD.
As for the idling issue, when I bought the Ranger it had idling issues too. Once it got moving down the road, the throttle was very erratic. I did not have a check engine light. A KOEO and KOER test revealed a Throttle Position Sensor (TPS) bad. Pull the codes and you may find your problem. Hope this helps.
