Using Oil
Old Dec 28, 2006 | 05:25 PM
goodspeed928's Avatar
goodspeed928
Question Using Oil
I just checked my oil, im down 3/4 qt after 2800mi
97 Ranger 3.0. No smoke, Tale pipe clean, No leaks.
88898MI
Old Dec 28, 2006 | 07:40 PM
jimw411's Avatar
jimw411
Thats exceptable, it will suck oil out through the breather hose and the PCV valve. If you do a lot of city driving, it will consume more oil as well. My truck has 66,600 miles and uses about 1/4 of a quart between changes, and has since the day i bought it. I do a majority of highway driving though.
Old Dec 28, 2006 | 09:48 PM
sfcwoodret's Avatar
sfcwoodret
Check the head gaskets also.
Old Dec 29, 2006 | 12:27 PM
goodspeed928
"Check the head gaskets also."
Motor clean as new
Old Dec 30, 2006 | 09:00 AM
pawpaw's Avatar
pawpaw
Have you changed brands or viscosity lately, or changed your driving style, routine, or have your driving conditions changed during this time ????
Old Dec 30, 2006 | 09:09 AM
goodspeed928
NOPE, I will do a change today and check offen.
Old Dec 30, 2006 | 09:26 AM
pawpaw's Avatar
pawpaw
Well something is going on, if it just suddenly began doing this.
Stuck or broken ring/s, fuel dillution, lube with lower volitility or higher NOACK % evaporation loss, come to mind.
Are you having, or noticing any driveability changes????
Good idea imo, to change the oil & keep an extra eye on the fill level. I check all my fluids at every fuel up!!!!
