foam in oil?!?!?
Old Dec 28, 2006 | 01:35 PM
84f250460's Avatar
84f250460
foam in oil?!?!?
hi again guys.. well today i went out to check my oil and i found a bit of foam in there. any ideas where it came from?
Old Dec 28, 2006 | 06:49 PM
99yellowgt's Avatar
99yellowgt
Sounds like water. Headgasket?
Old Dec 29, 2006 | 04:03 AM
cpettymore7777's Avatar
cpettymore7777
check the coolant level. if its low it is the head gasket. but i had my 1980 have some foamy oil when it was setting around for a few weeks in the fall. the water was condensation in the oil pan. my eng temp only hits 190 so it does not boil out as fast as it should.
Old Dec 29, 2006 | 09:55 AM
84f250460's Avatar
84f250460
well i just got it from the used lot where it sat awhile more than likely so if the collant isnt low should i just give 'er a good flush and some fresh oil?
Old Dec 29, 2006 | 01:30 PM
cpettymore7777
give it a shot and keep a eye on it
Old Dec 29, 2006 | 10:50 PM
Old Rust Bucket's Avatar
Old Rust Bucket
There sure seems to be alot of these "foam in the oil threads" lately. Must be in the weather.
Old Dec 30, 2006 | 05:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
It is the weather. Engines, especially ones with big slab sides, do not heat up rapidly if at all in the winter. Short trips will always result in condensation forming in the oil. The foam comes from the detergent in the oil doing it's job and emulsifying with it until engine heat can drive it off.
