PCM-ECM replacement
Old Dec 27, 2006 | 09:30 PM
trukerdanz's Avatar
trukerdanz
PCM-ECM replacement
Have spark knock issue, TSB addressing this problem states the coil pack and PCM need to be replaced, already did the coil pack and went to order the pcm and was told that they are programmable and if it is working shouldn't need to be replaced just "flashed" or updated. Sure would be alot cheaper, anyone know why the PCM would or could need to be replaced if it isn"t fried? Or is Ford just trying to sell parts? Thanks.
Old Dec 29, 2006 | 12:49 AM
Wilber15's Avatar
Wilber15
It's a re-flash. Did you have the misfire in the first 1000 rpm's code? It is a re-flash so the module waits longer before monitoring for misfires thus ignoring the startup misfires. Just take it to a dealer and get it reflashed.....
TimothyJames
1997 - 2003 F150
Jan 14, 2017 07:55 PM
JordoTW
1983 - 2012 Ranger & B-Series
21
Jan 10, 2016 10:06 PM
RTrud
Jul 13, 2015 06:37 PM
Rider48
Modular V8 (4.6L, 5.4L)
Jun 19, 2015 09:26 PM
Mastagunz
Aug 25, 2011 09:19 PM
