Block Heater
Old Dec 27, 2006 | 12:53 PM
FloridaF250's Avatar
FloridaF250
Block Heater
On the SD forum i read that the block heater is standard but the cord is what you have to get. Is this true? The author of that thread thought that to be the case.
Old Dec 27, 2006 | 01:24 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
The heating element is built into the bock my Int'l.
It is the cord that is an option or is included iin ceratian cold weather states according to Ford.
You need to order the cord from either Int'l or Ford.
Enjoy... and keep warm.
Old Dec 27, 2006 | 01:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Get from International...1/2 price of Ford. Same part.
Old Dec 27, 2006 | 04:49 PM
jimh425's Avatar
jimh425
Check out ebay also. There's a seller in FL. I just got mine from him. It took a few days for shipping, but should be really fast since you appear to be in FL. He shipped fast.
Old Dec 28, 2006 | 06:08 AM
FloridaF250
Thanks, not that I need it in Florida but I never know when I have to leave the state and there's nothing but colder climates all around.
Old Dec 30, 2006 | 12:58 PM
Reglob5's Avatar
Reglob5
I have it and use it but notice nothing. The temp guage is as cold as if I had not pluged in. I'm in Chicago and my truck is newer, so I will start anyhow, but Thought the coolant temp. would be a little warm and have some heat, but no dice. Is my heater bad?
Old Dec 30, 2006 | 02:31 PM
mrxlh's Avatar
mrxlh
Yes its probably bad, I just used mine for the first time in my 05 the other day and the temp gauge was just off the bottom, and it warmed up really quick. This was the same way it worked in my 03.
Old Dec 30, 2006 | 04:14 PM
mjlevi's Avatar
mjlevi
hey listen,... I thought the same thing when I first used my block heater,...no heat, temp gauge hadn't even moved...so here's what to try, plug it in again overnight, whatever...go outside, do not start the truck, open the hood and feel the upper radiator hose and see if it warm, if it is...then it is working, the heater basically heats the coolant in the upper engine area (heads) etc., there is still some very cool coolant in the system, so on start-up, the water pump moves it around and it blends the warm and cool coolant, so it will not be as warm as you may think or want initially, but it will warm up faster after you start-up and drive, I would have to bet that it is working !!
