FE distributor gear lash
Old Dec 27, 2006 | 02:59 AM
1pump's Avatar
1pump
Finally started working on my '76 F250 project. Right now I'm trying to keep the old 360/390 (not sure which yet) alive until I get a new engine built for it, and maybe fix about 153 other problems it has.
Anyway, during a tuneup the other day I grabbed hold of the armature in the distributor and discovered that there's quite a bit of rotational play in it. It doesn't move up or down, or wiggle side to side. It turns about 1/4 inch in both directons before it stops, like it has a bad distributor gear or cam gear. It has the old SSI ignition (the one Ford made before Duraspark).
Is that kind of slop normal? It seems to me that it would raise hell with the timing. It also has an intermittent low RPM misfire that comes and goes at random, and I think this might be the culprit. I know it should have a tiny bit of lash, but this seems excessive.
Old Dec 27, 2006 | 04:37 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well it is obviously worn a bit...But some lash is just fine..and a long as the motor runs good dont worry about it..as the motor when running will take the slack out one way..and you just make up for it with turning the Cap (dizzy) when you set the timming...No Biggy! as long as your timming isnt jumping around while your running Dont worry about it... JMO..
RJ
Old Dec 27, 2006 | 08:07 AM
Freightrain's Avatar
Freightrain
Are you seeing the "advance" timing as you turn it? That will give you the illusion that there is slop, but it should spring back after you turn it, showing it's still sprung and working.
Old Dec 27, 2006 | 12:16 PM
kotzy's Avatar
kotzy
Since the dist. shaft is not one piece what you are seeing is movement in the mechanical advance. You would have to pull the top shaft off the lower to see the lash between the dist. gear and cam gear. The dist.shaft drives the oil pump putting a very steady load on the driven side of the gear teeth and very little if any movement in the lash between the two gears.
kotzy
